Date/Time: Fri, 16 Oct 2026 14:22:39 +0000
Connecting Sierra Chart
View Count: 832
| [2022-02-14 15:10:32] |
| User565966 - Posts: 2 |
Hello, I would like to know how I could setup my SierraChart account to have real time data feed from the CME exchanges with AMP futures broker ? Is it possible ? What's the process please ? Is it supported to use Teton Futures Order Routing + Denali RealTime data and MBO with AMP Futures ? - IF YES : How should I proceed ? - IF NO : Knowing that I have less than $5000 to open a futures live account what do you recommend ? |
| [2022-02-14 18:09:57] |
| John - SC Support - Posts: 48222 |
AMP does not support the Teton Order Routing Service at this time. So you can not have that setup with AMP. It is therefore your choice as to whether you change brokers or stay with AMP. If you want to change brokers to one that supports the Teton Order Routing service, then you will find the list at Step #2 at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions You would then follow the steps outlined in those Setup Instructions -- If you stay with AMP, then you would be setup with CQG (most likely) for your order routing. In which case, you would follow the instructions at the following link to setup your Sierra Chart to connect to your CQG account: CQG Trading Platform Service: Setup Instructions And to get the Denali Exchange Data Feed for the CME Group data, you will then follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
