Date/Time: Fri, 16 Oct 2026 14:22:10 +0000
No recibo datos en tiempo real.
View Count: 784
| [2022-02-14 15:09:28] |
| Monkey.D.Luffy - Posts: 4 |
Buenos dias. Tengo el paquete 11 y cuenta con CQG, he conectado la cuenta en archivo, ajuste de servicio datos/operacion. Al abrir los chartbooks tengo que actualizar el simbolo en el caso del miniSP500, tengo ESH22, y al buscar el simbolo actual me sale F.US.EPH22. AL ajustarlo en el grafico se queda todo en blanco y me salen dos cuadrados, el primero naranja con el siguiente mensaje "Symbol is unknown. Click for symbol information. Real time data subscription for instrument is not enabled", y otro rojo "Download Falied. Error downloading historical INtraday data forF.US.EPH22 Instrument is not allowed. , asi como en el dashboard me salen 0 contratos activos. Desconozco el motivo, he probado a instalar la ultima version y sigo con el mismo problema. Un saludo. |
| [2022-02-14 18:05:05] |
| John - SC Support - Posts: 48222 |
From Google Translate: Good morning.
I have package 11 and it has CQG, I have connected the account on file, data/operation service adjustment. When opening the chartbooks I have to update the symbol in the case of the miniSP500, I have ESH22, and when looking for the current symbol I get F.US.EPH22. When adjusting it on the graph everything goes blank and I get two squares, the first orange with the following message "Symbol is unknown. Click for symbol information. Real time data subscription for instrument is not enabled", and another red "Download Falied Error downloading historical INtraday data forF.US.EPH22 Instrument is not allowed., as well as in the dashboard I get 0 active contracts. I do not know the reason, I have tried to install the latest version and I continue with the same problem. All the best. We see that you just finished setting up the Denali Exchange Data Feed. You should be receiving the Real-Time data from Denali now. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
