Date/Time: Fri, 16 Oct 2026 16:50:10 +0000
Default Char Bart Spacing not possible to set per chart
View Count: 812
[2022-02-14 11:13:13]
YSS - Posts: 120
I need to change the space between candlesticks, there is a setting for this in Global Settings >> Graphics Settings >> Other but this is for all charts.
I only want this to certain charts, but this field is locked and not editable in Graphics Settings - Chart.
Please advise since this should be able to be set per chart.
Thanks!
[2022-02-14 14:58:55]
This is not supported per chart. It is a global default setting.
You should know that you can change the chart bars spacing in any chart:
Working With Charts: Changing Bar Spacing
[2022-02-14 15:08:47]
YSS - Posts: 120
Thanks, it's okay I can live with it, but the bars spacing is not what I mean, this functionality you quote is increasing the overall zoom level and increasing the bar size width, what i'm talking about is the spacing between the bars without affecting the bars themselves (A functionality that Eze EMS / Realtick has but missing on SC)
