Date/Time: Sat, 28 Nov 2026 12:52:12 +0000
Update to new version stops uploading intraday data
View Count: 855
[2022-02-14 07:57:03]
User350416 - Posts: 43
I updated to the new version, which erased my rithmic credentials in Data Trade service settings.
After putting my credentials back on, and SC connecting to Rithmic I still receive NO DATA and charts don't get updated.
I have package 11 and followed all posts re Rithmic connectivity settings.
I have also the " Set the Allow Support for Sierra Chart Data Feeds option to Yes" and I don't have the M indicator next to the symbol.
Going backward to the previous SC version does not either upload the data, so I'm totally blocked.
Can you please help?
I can't trade
Thank you
image220214 08h50s57.146.png / V - Attached On 2022-02-14 07:54:51 UTC - Size: 8.46 KB - 217 views
image220214 08h16s11.065.png / V - Attached On 2022-02-14 07:54:56 UTC - Size: 47.63 KB - 282 views
[2022-02-14 11:00:24]
You need to translate the symbols to the new Rithmic symbol format. Refer to this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
[2022-02-14 12:07:43]
Ok, thank you
That solved the isse
