Date/Time: Sat, 04 May 2024 13:06:54 +0000
NASDAQ Total View Data Feed
View Count: 741
[2022-02-12 22:31:16] |
wingz - Posts: 121 |
I use your Denali data feed for REAL TIME Futures data. Every day I have 5 chartbooks open that uses real time data for ES, YM and NQ futures symbols. I also have 1 chartbook that has stock symbols, on Daily and Weekly charts, that I DO NOT need real time data for...........I only need 10 minute delayed data for the stock symbols. I use the SC Data-All Services. If I go to the link that you suggest, Global Symbol Settings: Update Global Symbol Settings, and update the symbol settings.............will that give me the 10 min delayed data on stocks and NOT effect any of my real time futures symbols? AND.......is that all I need to do? All of my real time futures symbols work perfectly and I don't want to effect any of the real time data for those.
[2022-02-14 16:32:10] |
John - SC Support - Posts: 31362 |
You have things correct. Update your Symbol Settings, if you have not done this recently and then set your Current Selected Service to SC Data - All Services. You will then be able to get the delayed streaming data for U.S. stocks.
[2022-02-14 22:14:42] |
Instructions to update symbol settings: Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
