Date/Time: Thu, 02 May 2024 01:08:09 +0000
Viewing stocks on SC DOM
View Count: 865
[2014-04-14 14:44:06] |
bwalks123 - Posts: 122 |
I am trying to set up a DOM to watch order flow and depth for stocks but cant get it set up correctly. It keeps showing fills in between .01 -.001 increments making it really hard to read. Can this be done or is the DOM strictly for futures? thx
[2014-04-14 17:03:14] |
Yes you can do this. You need to increase the Tick Size in Chart >> Chart Settings. Let us know if you need more help.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-14 17:03:30
