Date/Time: Mon, 02 Nov 2026 14:40:56 +0000
custom chart header not showing
View Count: 1054
| [2022-02-10 12:43:01] |
| CAACAP - Posts: 51 |
I have a chart that doesn't show the chart header(Change on the day, P&L etc) I have other charts that i created that does show.
| [2022-02-15 17:00:46] |
You need to enable the Chart Header: Chart Settings: Region Data Lines (List) (Chart >> Chart Settings >> Regions >> Region Data Line menu) Also refer to: Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
