Date/Time: Tue, 03 Nov 2026 14:18:00 +0000
Sierra Engineering Please Help
View Count: 965
| [2022-02-04 17:15:16] |
| User769783 - Posts: 208 |
Hello, I have a very specific question regarding Market Stats like Tick-NQ, Tick-SP, and Tick-TF. Without going into the specifics of my strategy, I really need to speak to someone with Sierra Engineering to help my understanding. I cannot find any information on this matter anywhere. I am trying to relate these market stats to their related Futures. I know you folks are very busy keeping Sierra Chart the best platform for serious traders, big thanks for this as well. If someone can find the time to reach out to me, even through email, I will be too grateful. Thanks and much continued success in SC endeavors. |
| [2022-02-04 18:35:21] |
| User220914 - Posts: 239 |
you can buy time and get the time you want to talk. otheriwse you will need to be very specific and at least pose your question trust me when i tell you this.. whatever you are working on may be a great addition to your trading but habing others see it will not ruin or change the outcome of your trading or your profits. its ok to post up an idea here if you are seeking a solution. that is all im trying to say. no offense but i think sierra has 10s of thousands of users an SOS call out for engineering to call you most likely wont help you much but post your question and since im taking a break maybe i can help you |
| [2022-02-05 06:21:35] |
| 1+1=10 - Posts: 270 |
Hi OP, Perhaps you’ve already read the docs on the SC market stats but just in case: Sierra Chart Market Statistics |
| [2022-02-05 19:18:04] |
You still never stated your specific question? do you want anyone to try and help you?
| [2022-02-07 15:31:23] |
I need to speak with Sierra Engineering specifically. Thank you.
| [2022-02-07 15:46:37] |
All of the information we have about market statistics is here: Sierra Chart Market Statistics There is no way to relate these to the futures contracts. They are completely independent from each other and have no relationship. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-07 16:16:19] |
Thanks, but the information I need is not there. I have a more specific question about using the market stats as Symbol and another market as Trade only symbol.
| [2022-02-07 17:47:30] |
We would not advise doing this. There would be issues associated with this that would have to be worked out. We really strongly advise not to do this. We simply do not want to get involved in supporting this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-07 17:47:56
| [2022-02-07 18:16:10] |
Understood, but I have a very strong reason why I'd like to. I will do so at my own discretion and will not to look support about any issues if any. Thanks.
