Date/Time: Sun, 19 May 2024 01:11:42 +0000
LMAX V1119
View Count: 1038
[2014-04-11 14:41:58] |
ABTrader - Posts: 32 |
SC Support, I have an error related to the unmatched position that did not exist in the LMAX web GUI (DEMO FIX account). It is flat for this symbol GDAXI on LMAX web. But There is a Long position that I simply can not close it from SC. Refresh trade position did not get rid of it. Here is an error msg. Trade Order Error - LMAX order update (Rejected). Info: QUANTITY_NOT_VALID. Internal Order ID: 11815. Service Order ID: (none). Symbol: GDAXI | 2014-04-11 14:33:58 Thanks. |
[2014-04-11 16:22:43] |
Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails80.html That error message is not related. Also, you will want to use Trade >> Use Fill Calculated Positions-Global with LMAX for the Trade Statistics and Trades in the Trade Activity Log to function properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-11 16:23:13
