Date/Time: Mon, 29 Apr 2024 00:36:02 +0000
Нет соединения.
View Count: 1297
[2014-04-11 12:20:26] |
LBatters - Posts: 1 |
Установил Sierra Chart.Запустил.Вводил данные для соединения и от CQG,и от Т4, и от TD Ameritrade ничего не конектит ,что делать то?Вот ссылка на скрин экрана http://pixs.ru/showimage/12jpg_7198066_11644486.jpg
[2014-04-13 00:20:04] |
We apologize for the delay. Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
