Date/Time: Fri, 03 May 2024 23:50:17 +0000
5. If you are using the following services (Global Settings >> Data/Trade Service Settings
View Count: 474
[2022-02-01 16:10:50] |
User39772 - Posts: 311 |
Hello, As soon as I switch from Global Settings >> Data/Trade Service Settings -> SC Data All Services to Global Settings >> Data/Trade Service Settings -> Interactive Brokers [trading] the delayed new Nasdaq data feed seems to stop. Does this mean when using the new data feed with market depth it is not possible to send orders to IB ? |
[2022-02-01 17:19:03] |
John - SC Support - Posts: 31362 |
You are not setup with the new NASDAQ feed. Go through the instructions in the first post at this link: How to Use New NASDAQ Total View Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-01 18:59:26] |
Hello, I accomplished all steps tor receive delay data. 5. If you are using the following services (Global Settings >> Data/Trade Service Settings ): -Teton CME Order Routing -SC/TT Order Routing -SC Data-All Services -Trading Evaluator services (the live evaluator service will require upcoming release 2352 to access delayed NASDAQ data. Real-time is now supported.) -LMAX demo/Live Trading services If you require delayed data, and you are not using one of the above listed services, then you need to install another installation of Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Since Interactive Brokers [trading] is not listed above, I understand, that I have to install another installation of Sierra Chart. Is that understanding correct ? |
[2022-02-01 19:59:27] |
Yes that is correct. If you want delayed data from the NASDAQ TotalView data feed.
[2022-02-01 20:41:10] |
Is that also the case, if I use realtime data or does it work with one single instance of SC, that is set to Interactive Brokers [trading] ?
[2022-02-01 22:53:40] |
If you are setup with the Real-Time data (which you are not as of this writing) then you will be able to use it with Interactive Brokers.
