Date/Time: Mon, 29 Apr 2024 08:24:04 +0000
TPO Value Area Lines problem
View Count: 2232
[2013-04-25 03:25:20] |
joshtrader - Posts: 439 |
The "One period Only" option for the TPO Value Area Lines is including the last bar of the prior day, and it is using this in the calculations for the subsequent bars. http://screencast.com/t/nzI7yoEns Also, when using day and evening sessions, using this option seems to begin the profile two bars (using 30m bars) before midnight, instead of the first bar of the last trading session. Date Time Of Last Edit: 2013-04-25 03:25:52
[2013-04-25 03:37:14] |
We recommend referring to the documentation for this.
[2013-04-25 03:58:48] |
I have looked at documentation. I see nothing that would indicate that when the "one period only" and "new period at day session start" are both set to Yes, that the calculation should incorrectly begin one bar (and in this case one day) too early. Is the problem not clear from looking at the picture? |
[2013-04-25 20:27:16] |
Check the documentation again. You are misunderstanding the purpose of that setting. It is not designed to do what you expect.
