Date/Time: Tue, 10 Nov 2026 18:47:09 +0000
No data for Teton Service
View Count: 862
| [2022-01-31 01:01:58] |
| User879924 - Posts: 50 |
Hi, I have just switched over to Teton via Edge Clear. I followed the instructions from the Sierra support thread and I have ensured that allow support for SC data feeds is selected to yes but I have no live data. When I switch back to SC data- All services I have no problems and charts work as expected. I have sent you a msg log to assist in the trouble shooting. |
| [2022-01-31 01:07:01] |
You need to Translate the symbols with this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-31 01:07:12
| [2022-01-31 01:56:50] |
Thank you this seems to have resolved the problem but created another one for me. On my NQ chart I can use the hand tool to click and drag the chart however I like it. My ES chart has the same scale settings but I cannot click and drag it with the hand tool. I have the global settings to allow the hand tool to click and drag. |
| [2022-01-31 02:54:15] |
Can you at least move the chart left and right with the Hand tool?
| [2022-01-31 04:35:15] |
it has been resolved thank you
