Date/Time: Wed, 15 May 2024 08:29:12 +0000
CTS FIX: Received a FIX message from an unknown sender.
View Count: 1054
[2014-04-10 20:08:42] |
T44 - Posts: 363 |
Is this caused by the clock being out of sync? Or yet another problem with CTS? Software version: 1117 | 2014-04-10 15:05:06
Usage end date: 2014-09-06 | 2014-04-10 15:05:06 Enabled for: Sierra Chart Historical Data Service. | 2014-04-10 15:05:06 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-04-10 15:05:06 Active service: CTS T4 | 2014-04-10 15:05:06 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-04-10 15:05:06 2014-04-10 20:05:06 Local computer clock time | 2014-04-10 15:05:06 2014-04-10 19:05:06 GMT time | 2014-04-10 15:05:06 2014-04-10 15:05:06 Time zone adjusted time | 2014-04-10 15:05:06 Time difference to server time: 3601 seconds. | 2014-04-10 15:05:06 WARNING: Your computer's clock is off by 3601 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2014-04-10 15:05:06 Program path: C:\SierraChart\ | 2014-04-10 15:05:06 Data Files path: C:\SierraChart\Data\ | 2014-04-10 15:05:06 OS Version Number: 6.1 | 2014-04-10 15:05:06 Checking for new symbol settings for cts | 2014-04-10 15:05:06 Symbol settings are up-to-date for cts | 2014-04-10 15:05:07 Checking for large (over 80 MB) intraday data files to move data out of. Please wait.... | 2014-04-10 15:05:08 Completed checking of 10 Intraday data files (*.scid). | 2014-04-10 15:05:09 Limiting the number of days back for the continuous futures chart to 7.1293634 years based on the account type. | 2014-04-10 15:05:10 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-04-10 15:05:29 CTS FIX - Firm: Dorman | 2014-04-10 15:05:29 Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-04-10 15:05:29 The network socket is connected. | 2014-04-10 15:05:29 Starting SSL connection on the socket. | 2014-04-10 15:05:29 SSL socket is connected. | 2014-04-10 15:05:30 CTS FIX: Sending the Logon message. | 2014-04-10 15:05:30 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:30 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:31.03645=1372=A373=1058=Sending Time Accuracy problem10=176 | 2014-04-10 15:05:30 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:30 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:31.03645=1372=A373=1058=Sending Time Accuracy problem10=176 | 2014-04-10 15:05:30 Socket closed. No error. | 2014-04-10 15:05:30 SSL shutdown indicates not able to send 'close notify'. | 2014-04-10 15:05:30 The SSL socket was shut down. | 2014-04-10 15:05:30 The SSL socket object has been freed. SSL state is now disconnected. | 2014-04-10 15:05:30 Socket has been shutdown and closed. | 2014-04-10 15:05:30 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-04-10 15:05:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-10 15:05:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-10 15:05:30 CTS FIX: Disconnected. | 2014-04-10 15:05:30 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-10 15:05:30 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-04-10 15:05:33 CTS FIX - Firm: Dorman | 2014-04-10 15:05:33 Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-04-10 15:05:33 The network socket is connected. | 2014-04-10 15:05:33 Starting SSL connection on the socket. | 2014-04-10 15:05:33 SSL socket is connected. | 2014-04-10 15:05:33 CTS FIX: Sending the Logon message. | 2014-04-10 15:05:34 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:34 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:34.76445=1372=A373=1058=Sending Time Accuracy problem10=187 | 2014-04-10 15:05:34 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:34 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:34.76445=1372=A373=1058=Sending Time Accuracy problem10=187 | 2014-04-10 15:05:34 Socket closed. No error. | 2014-04-10 15:05:34 SSL shutdown indicates not able to send 'close notify'. | 2014-04-10 15:05:34 The SSL socket was shut down. | 2014-04-10 15:05:34 The SSL socket object has been freed. SSL state is now disconnected. | 2014-04-10 15:05:34 Socket has been shutdown and closed. | 2014-04-10 15:05:34 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-04-10 15:05:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-10 15:05:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-10 15:05:34 CTS FIX: Disconnected. | 2014-04-10 15:05:34 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-10 15:05:34 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-04-10 15:05:37 CTS FIX - Firm: Dorman | 2014-04-10 15:05:37 Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-04-10 15:05:37 The network socket is connected. | 2014-04-10 15:05:37 Starting SSL connection on the socket. | 2014-04-10 15:05:37 SSL socket is connected. | 2014-04-10 15:05:37 CTS FIX: Sending the Logon message. | 2014-04-10 15:05:37 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:38 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:38.52445=1372=A373=1058=Sending Time Accuracy problem10=185 | 2014-04-10 15:05:38 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:38 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:38.52445=1372=A373=1058=Sending Time Accuracy problem10=185 | 2014-04-10 15:05:38 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:38 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:38.52458=FIXLogin Time Tag Accuracy Problem - Out of time window10=225 | 2014-04-10 15:05:38 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:38 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:38.52458=FIXLogin Time Tag Accuracy Problem - Out of time window10=225 | 2014-04-10 15:05:38 Socket closed. No error. | 2014-04-10 15:05:38 SSL shutdown indicates not able to send 'close notify'. | 2014-04-10 15:05:38 The SSL socket was shut down. | 2014-04-10 15:05:38 The SSL socket object has been freed. SSL state is now disconnected. | 2014-04-10 15:05:38 Socket has been shutdown and closed. | 2014-04-10 15:05:38 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-04-10 15:05:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-10 15:05:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-10 15:05:38 CTS FIX: Disconnected. | 2014-04-10 15:05:38 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-10 15:05:38 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-04-10 15:05:41 CTS FIX - Firm: Dorman | 2014-04-10 15:05:41 Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-04-10 15:05:41 The network socket is connected. | 2014-04-10 15:05:41 Starting SSL connection on the socket. | 2014-04-10 15:05:41 SSL socket is connected. | 2014-04-10 15:05:41 CTS FIX: Sending the Logon message. | 2014-04-10 15:05:41 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:41 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:42.45545=1372=A373=1058=Sending Time Accuracy problem10=183 | 2014-04-10 15:05:41 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:41 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:42.45545=1372=A373=1058=Sending Time Accuracy problem10=183 | 2014-04-10 15:05:41 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:41 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:42.45558=FIXLogin Time Tag Accuracy Problem - Out of time window10=223 | 2014-04-10 15:05:41 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:41 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:42.45558=FIXLogin Time Tag Accuracy Problem - Out of time window10=223 | 2014-04-10 15:05:41 Socket closed. No error. | 2014-04-10 15:05:41 SSL shutdown indicates not able to send 'close notify'. | 2014-04-10 15:05:41 The SSL socket was shut down. | 2014-04-10 15:05:41 The SSL socket object has been freed. SSL state is now disconnected. | 2014-04-10 15:05:41 Socket has been shutdown and closed. | 2014-04-10 15:05:41 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-04-10 15:05:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-10 15:05:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-10 15:05:41 CTS FIX: Disconnected. | 2014-04-10 15:05:41 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-10 15:05:41 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-04-10 15:05:45 CTS FIX - Firm: Dorman | 2014-04-10 15:05:45 Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-04-10 15:05:45 The network socket is connected. | 2014-04-10 15:05:45 Starting SSL connection on the socket. | 2014-04-10 15:05:45 SSL socket is connected. | 2014-04-10 15:05:45 CTS FIX: Sending the Logon message. | 2014-04-10 15:05:45 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:45 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:46.29345=1372=A373=1058=Sending Time Accuracy problem10=187 | 2014-04-10 15:05:45 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:45 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:46.29345=1372=A373=1058=Sending Time Accuracy problem10=187 | 2014-04-10 15:05:45 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:45 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:46.29358=FIXLogin Time Tag Accuracy Problem - Out of time window10=227 | 2014-04-10 15:05:45 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:45 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:46.29358=FIXLogin Time Tag Accuracy Problem - Out of time window10=227 | 2014-04-10 15:05:45 Socket closed. No error. | 2014-04-10 15:05:45 SSL shutdown indicates not able to send 'close notify'. | 2014-04-10 15:05:45 The SSL socket was shut down. | 2014-04-10 15:05:45 The SSL socket object has been freed. SSL state is now disconnected. | 2014-04-10 15:05:45 Socket has been shutdown and closed. | 2014-04-10 15:05:45 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-04-10 15:05:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-10 15:05:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-10 15:05:45 CTS FIX: Disconnected. | 2014-04-10 15:05:45 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-10 15:05:45 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-04-10 15:05:48 CTS FIX - Firm: Dorman | 2014-04-10 15:05:48 Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-04-10 15:05:48 The network socket is connected. | 2014-04-10 15:05:48 Starting SSL connection on the socket. | 2014-04-10 15:05:48 SSL socket is connected. | 2014-04-10 15:05:49 CTS FIX: Sending the Logon message. | 2014-04-10 15:05:49 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:49 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:50.06845=1372=A373=1058=Sending Time Accuracy problem10=182 | 2014-04-10 15:05:49 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:49 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:50.06845=1372=A373=1058=Sending Time Accuracy problem10=182 | 2014-04-10 15:05:49 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:49 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:50.06858=FIXLogin Time Tag Accuracy Problem - Out of time window10=222 | 2014-04-10 15:05:49 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:49 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:50.06858=FIXLogin Time Tag Accuracy Problem - Out of time window10=222 | 2014-04-10 15:05:49 Socket closed. No error. | 2014-04-10 15:05:49 SSL shutdown indicates not able to send 'close notify'. | 2014-04-10 15:05:49 The SSL socket was shut down. | 2014-04-10 15:05:49 The SSL socket object has been freed. SSL state is now disconnected. | 2014-04-10 15:05:49 Socket has been shutdown and closed. | 2014-04-10 15:05:49 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-04-10 15:05:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-10 15:05:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-10 15:05:49 CTS FIX: Disconnected. | 2014-04-10 15:05:49 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-10 15:05:49 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-04-10 15:05:52 CTS FIX - Firm: Dorman | 2014-04-10 15:05:52 Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-04-10 15:05:52 The network socket is connected. | 2014-04-10 15:05:52 Starting SSL connection on the socket. | 2014-04-10 15:05:52 SSL socket is connected. | 2014-04-10 15:05:53 CTS FIX: Sending the Logon message. | 2014-04-10 15:05:53 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:53 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:54.01545=1372=A373=1058=Sending Time Accuracy problem10=178 | 2014-04-10 15:05:53 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:53 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:54.01545=1372=A373=1058=Sending Time Accuracy problem10=178 | 2014-04-10 15:05:53 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:53 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:54.01558=FIXLogin Time Tag Accuracy Problem - Out of time window10=218 | 2014-04-10 15:05:53 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:53 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:05:54.01558=FIXLogin Time Tag Accuracy Problem - Out of time window10=218 | 2014-04-10 15:05:53 Socket closed. No error. | 2014-04-10 15:05:53 SSL shutdown indicates not able to send 'close notify'. | 2014-04-10 15:05:53 The SSL socket was shut down. | 2014-04-10 15:05:53 The SSL socket object has been freed. SSL state is now disconnected. | 2014-04-10 15:05:53 Socket has been shutdown and closed. | 2014-04-10 15:05:53 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-04-10 15:05:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-10 15:05:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-10 15:05:53 CTS FIX: Disconnected. | 2014-04-10 15:05:53 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-10 15:05:53 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-04-10 15:05:56 CTS FIX - Firm: Dorman | 2014-04-10 15:05:56 Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-04-10 15:05:56 The network socket is connected. | 2014-04-10 15:05:56 Starting SSL connection on the socket. | 2014-04-10 15:05:56 SSL socket is connected. | 2014-04-10 15:05:56 CTS FIX: Sending the Logon message. | 2014-04-10 15:05:57 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:05:57 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:57.77445=1372=A373=1058=Sending Time Accuracy problem10=193 | 2014-04-10 15:05:57 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:05:57 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:05:57.77445=1372=A373=1058=Sending Time Accuracy problem10=193 | 2014-04-10 15:05:57 Socket closed. No error. | 2014-04-10 15:05:57 SSL shutdown indicates not able to send 'close notify'. | 2014-04-10 15:05:57 The SSL socket was shut down. | 2014-04-10 15:05:57 The SSL socket object has been freed. SSL state is now disconnected. | 2014-04-10 15:05:57 Socket has been shutdown and closed. | 2014-04-10 15:05:57 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-04-10 15:05:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-10 15:05:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-10 15:05:57 CTS FIX: Disconnected. | 2014-04-10 15:05:57 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-10 15:05:57 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-04-10 15:06:00 CTS FIX - Firm: Dorman | 2014-04-10 15:06:00 Resolved address fix.t4login.com to IP 74.201.6.106 | 2014-04-10 15:06:00 The network socket is connected. | 2014-04-10 15:06:00 Starting SSL connection on the socket. | 2014-04-10 15:06:00 SSL socket is connected. | 2014-04-10 15:06:00 CTS FIX: Sending the Logon message. | 2014-04-10 15:06:01 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:06:01 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:06:01.69045=1372=A373=1058=Sending Time Accuracy problem10=180 | 2014-04-10 15:06:01 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:06:01 FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20140410-20:06:01.69045=1372=A373=1058=Sending Time Accuracy problem10=180 | 2014-04-10 15:06:01 CTS FIX: Received a FIX message from an unknown sender. Expected "Dorman", but received "". | 2014-04-10 15:06:01 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:06:01.69058=FIXLogin Time Tag Accuracy Problem - Out of time window10=220 | 2014-04-10 15:06:01 CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2014-04-10 15:06:01 FIX Message: 8=FIX.4.29=11135=534=249=56=50=T4FIX52=20140410-20:06:01.69058=FIXLogin Time Tag Accuracy Problem - Out of time window10=220 | 2014-04-10 15:06:01 Socket closed. No error. | 2014-04-10 15:06:01 SSL shutdown indicates not able to send 'close notify'. | 2014-04-10 15:06:01 The SSL socket was shut down. | 2014-04-10 15:06:01 The SSL socket object has been freed. SSL state is now disconnected. | 2014-04-10 15:06:01 Socket has been shutdown and closed. | 2014-04-10 15:06:01 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-04-10 15:06:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-04-10 15:06:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-04-10 15:06:01 CTS FIX: Disconnected. | 2014-04-10 15:06:01 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-04-10 15:06:01 |
[2014-04-10 20:35:32] |
