Date/Time: Sat, 31 Oct 2026 20:13:09 +0000
Copying Chart Drawings
View Count: 1036
| [2022-01-25 20:27:32] |
| User964846 - Posts: 38 |
Question 1: I am wondering, is there a way to share chart drawings between different instances of Sierra? Question 2: & if that is not possible, is there a way to share drawings between multiple chartbooks? Question 3: Unrelated Is there a way to prevent the main screen from resizing itself? I have enable moving the chart by grabbing the background, but when the chart window moves across the time axis, it resizes the price axis. Is there a way to prevent the chart from doing this? Thanks SC! you guys are awesome! Date Time Of Last Edit: 2022-01-25 20:44:42
| [2022-01-26 04:57:06] |
| User99735 - Posts: 234 |
Can create a custom study to do this. Do respond in Direct Message if interested.
| [2022-01-26 14:46:19] |
1. No. 2. Yes. Refer to: Copying Chart Drawings from Other Charts Automatically 3. Refer to: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-01 18:46:09] |
Hi User964846, Replying to your DM, yes my offer is still open. Please grant permission to me to send you direct messages.
