Date/Time: Mon, 06 May 2024 04:39:49 +0000
[Programming Help] - Trailing entries by study
View Count: 650
[2022-01-24 15:48:06] |
Mauro - Posts: 45 |
Hello, I use the trade management by study for my attached exit orders and it works great. Is there something similar for entries? I looked a lot at the other studies and I may have missed it. To be specific I do not want sierra to start the orders, like in a trading system, I want to put the order manually and then have sierra managing the entry level. For example: I usually enter my long at the High of the previous bar +1 tick stop. If that level is not touched and the next bar has a lower high, I would like sierra to automatically adjust (trail) the open stop order the the new lower high + 1 tick. Is there a way to do that? Thank you M |
[2022-06-21 10:35:15] |
You can certainly modify the Trade Management by Study to manage entry orders. The full source code is provided for Sierra Chart. Instructions: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-22 11:57:11] |
Luigi - Posts: 18 |
Look at the AutomatedTradeManagementBySubgraph.cpp. I used that as an example to make something similar you are trying to do: trigger entry decision by condition or manually, after that entry is managed by SC study. |
[2022-08-19 21:24:45] |
SabikiSensei - Posts: 74 |
Hi Luigi would you mind sharing your modification it?
