Date/Time: Wed, 15 May 2024 11:31:33 +0000
Alert Code Requests
View Count: 1402
[2014-04-09 19:03:49] |
infpz - Posts: 826 |
Please refresh my memory - need 2 alert codes (separate): 1. When the CCI cross either Line 1 or 2 from either direction, alert. 2. When the 89EMA cross the 34 EMA, alert. Thank you, Patrick Z |
[2014-04-10 12:54:03] |
2. is easy enough: =CROSSOVER(ID1.SG1,ID2.SG1), correct? Can someone help with 1? Would it be: =OR(CROSSOVER(SG1,100),CROSSOVER(SG1,-100)) Assuming Line 1 is 100 and Line 2 is -100? |
[2014-04-10 13:37:12] |
Sawtooth - Posts: 3996 |
Yes, that works. This works also, with the advantage that the alert follows the line value settings: =OR(CROSSOVER(SG1,SG3),CROSSOVER(SG1,SG4)) For further reference: For a visual test of an alert formula, add the Color Bar Based On Alert Condition study and put the formula in its Alerts tab, adding the ID# of the referenced study: =OR(CROSSOVER(ID3.SG1,ID3.SG3),CROSSOVER(ID3.SG1,ID3.SG4)) where ID3 is the CCI study. Price bars will color at every alert TRUE. |
[2014-04-10 13:37:55] |
perfect. thank you.
[2014-04-10 17:27:30] |
Both of these are documented here: https://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#examples Specifically refer to: Moving Average Crossover Alert Using Separate Moving Averages Alert for Commodity Channel Index (CCI) when it crosses its Line 2 or Line 3 Subgraphs: Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-10 17:28:25
