Date/Time: Tue, 14 May 2024 14:37:14 +0000
How can I display extended price lines in the Current Price Line Study?
View Count: 1821
[2014-04-09 07:53:33] |
User82828 - Posts: 44 |
How can I display extended price lines (to the right and left border of the screen) in the Current Price Line Study? I would like to display an extended price line also back to ALL former days til the left border of the screen and also til the right border of the screen. Is this possible? Furthermore, if I change the Line Style to "Dash" or "Dot" and change at the same time the Width/Size to values bigger than "1", then all Line styles are displayed in a solid way. How can I display e.g. a dashed price line, if the Width/Size ist set to values bigger than "1"? Thank you |
[2014-04-09 18:22:00] |
Increase the Number of Bars to Display On study Input with that study. There is also another Input with that study to forward project it. Furthermore, if I change the Line Style to "Dash" or "Dot" and change at the same time the Width/Size to values bigger than "1", then all Line styles are displayed in a solid way. How can I display e.g. a dashed price line, if the Width/Size ist set to values bigger than "1"? This is because it is actually not drawn as a continuous line and when the bar spacing is low you will get this kind of effect. Use the Point Draw Style instead:http://www.sierrachart.com/image.php?l=1397067693886.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-09 18:23:35
[2014-04-10 09:30:05] |
Thank you that all helps and works fine
