Date/Time: Mon, 02 Nov 2026 21:39:00 +0000
[Programming Help] - TPO value area lines
View Count: 1592
| [2022-01-18 09:28:44] |
| User822404 - Posts: 2 |
Hello. I am using Volume Per Bar in my study when I add the TPO VA Lines calculations, the VA and POC values are completely different than in the TPO Profile Chart study. I know TPO is based on time and hence there may be a mismatch in the calculations but maybe you have an idea how to include VA and POC in a graph where I use Vol Per Bar or Range Per Bar?
| [2022-01-18 16:29:10] |
| John - SC Support - Posts: 48388 |
The TPO Value Area Lines are going to be slightly different with non-Time-Based charts due to the way the bars cross the time points for the sub-period length of time. There is no fix for this other than to use time-based charts and then overlay the results onto the non-time-based. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-11 02:26:43] |
| User276160 - Posts: 3 |
I'm actually having the same issue but my POC's are sometimes off by several points 10+. Using the TPO VAL study on a time-based chart is better but still far from perfect. I guess I'll keep adding these manually everyday.
