Date/Time: Wed, 04 Nov 2026 15:26:46 +0000
Version 2345 tick chart has too many bars.
View Count: 814
[2022-01-17 15:35:47]
User752576 - Posts: 4
https://www.sierrachart.com/image.php?Image=1642433613427.png
The tick chart using the current version has too many bars. Volume and time charts seem fine.
[2022-01-17 16:08:09]
Update to the latest prerelease and re-download the data:
And also you really should be using the Denali Exchange Data Feed for data for the best and most reliable data:
Eventually support for tick by tick data from CQG for CME and EUREX will be removed. When that happens you will need to use the Denali Exchange Data Feed.
Date Time Of Last Edit: 2022-01-17 16:09:44
[2022-01-17 16:28:06]
Re post 99725
I did that and nothing changed on the trades chart.
