Date/Time: Fri, 26 Apr 2024 05:55:15 +0000
How to link orders filled (enter and exit positions) displayed on a chart
View Count: 1167
[2014-04-07 10:51:57] |
User99689 - Posts: 27 |
Global setting\Graphic setting\ Chart trading orders fills Entry/Exit Connecting Lines Primmary: i can't check (enable) this option so i can't link enter and exit positions. My question is how to link enter and exit positions. Thanks |
[2014-04-07 18:02:22] |
Refer to the documentation for this here: https://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
