Date/Time: Wed, 28 Oct 2026 03:36:22 +0000
Easily show order imbalances
View Count: 4535
| [2021-12-23 00:19:47] |
| aceoftrades12 - Posts: 23 |
While I've found nearly every possible option under the sun available in your charts (loving the flexibility), I'm finding a surprising lack of any such studies to easily display order imbalances and set color changes when such imbalances occur, the create boxes or something when there's stacked imbalances, and finally extend a rectangle (for zones) when such stacked imbalances are made (until invalidated by price trading through). All other trading platforms I've seen with footprint charts have less capabilities than yours, but they all seem to have more in the areas described above around imbalance. Am I just missing something obvious, or is this maybe something you're working on to add, or? Please advise, thanks much!
| [2021-12-23 15:01:48] |
For this: display order imbalances and set color changes when such imbalances occur
You can do this with the Numbers Bars study:Numbers Bars There are many coloring options available. For this: create boxes or something when there's stacked imbalances, and finally extend a rectangle (for zones) when such stacked imbalances are made (until invalidated by price trading through).
Use this study:Volume at Price Threshold Alert V2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-23 15:02:05
