Date/Time: Mon, 15 Aug 2022 10:28:41 +0000
Trade Activity Log
View Count: 723
[2014-04-04 18:26:47] |
infpz - Posts: 826 |
I am trying to better understand the circumstances where the TAL picks up historical fills and when it doesn't. If someone is logged into InfinityAT but not Sierra, and later logs into Sierra, will Sierra somehow pick up the "missed" fills as long as Trade Simulation Mode was not on? I presume no, but I would like to be certain on this.
[2014-04-04 19:51:45] |
Sierra Chart will always request the Non-simulated order fills whether Trade Simulation Mode is on or not, when it gets a successful connection to the trading server. The trading server will only provide them for the current trading day. They will be unavailable just after the end of the trading day from what I have observed. It is easy enough to test this. Make a few trades through Infinity AT. Start Sierra Chart, and you should see the "Fills" in the Trade Activity Log. You can then clear them and then reconnect to the data feed and they will reappear. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
