Date/Time: Mon, 19 Oct 2026 18:54:10 +0000
Child-client message
View Count: 1424
| [2021-12-17 16:09:05] |
| User587892 - Posts: 3 |
Starting this morning, after I placed few trades, suddenly orders give me a "Child-client" message, and they are never filled. This happens on both Sim and Live. I am using Denali and Rithmic for execution.
| [2021-12-17 16:28:29] |
| John - SC Support - Posts: 48255 |
When they are showing "Child-Client" then you would have a primary open order waiting to be filled, such as a Limit order. Once the parent order fills, then the child orders will convert to Open orders at the exchange.
| [2021-12-17 16:33:35] |
This happens when I hit "BUY/SELL MKT", which should fill nearly instantly on the instrument(NQ). Even so, this also happens in sim mode, which ostensibly ignores liquidity and order routing. |
| [2021-12-17 16:53:45] |
Chalk this one up to PEBKAC: I managed to fat-finger the TIF setting to set order for a future time. All good, thank you!
| [2021-12-17 19:58:08] |
Understood. Additionally, if you want fully server-side bracket orders, use the Teton order routing service: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
