Date/Time: Wed, 19 Aug 2026 23:39:49 +0000
[User Discussion] - Setting up rollover dates for bund future
View Count: 2215
[2014-04-04 12:25:53]
Bango - Posts: 76
I'm trying to make a back adjusted continuous chart off bund data with Sierra feed that can match Iqfeed's BD#C. Which settings should I use?
Thanks in advance.
[2014-04-04 18:39:35]
This can be done through the Rollover tab for the symbol in the Global Symbol Settings:
https://www.sierrachart.com/index.php?l=doc/doc_GlobalSettingsMenu.html
See attachment for the recommended settings.
imageBund rollover settings.png / V - Attached On 2014-04-04 18:38:39 UTC - Size: 14.64 KB - 707 views
[2014-04-04 20:23:05]
Bango - Posts: 76
Applying the recommended settings Eurex charts are not consistent with continuous back adjusted IQfeed's.
Where's the fault?
Thanks again.
[2014-04-04 21:31:01]
You can change the settings to match what IQ Feed uses . You will need to find out what they use.
[2014-04-05 13:22:33]
Bango - Posts: 76
I've found out that (and this apply only to Eurex data, no problem with CME's) even back adjusting IQfeed single contracts at the date rule recommended settings cannot match xx#C symbols back adjusted data.
Maybe there's an issue with calculations when it comes to Eurex data handling? Or IQfeed calculations are wrong.
Please check this out, I have to trust my data when volume profiling Eurex markets.
