Date/Time: Fri, 26 Apr 2024 01:06:44 +0000
How does Chart Calculator calculate the angle
View Count: 1914
[2014-04-04 03:59:53] |
BruceWilson - Posts: 14 |
Are you able to explain please how the chart calculator tool calculates the angle? I have used the following anchors: A1: 2014-02-27 20:00:00 - 138.794 A2: 2014-03-08 00:00:00 - 143.793 A price difference of 4.999 and time difference of 8 days and 4 hours Yet if I plug those figures into a trigonometry calculator such as http://www.carbidedepot.com/formulas-trigright.asp the resulting angle is quite different. Is the price and time figure somehow standardised e.g. to pips and minutes (or some other time factor - hours/days?) Thank you in advance for your explanation. Best wishes Bruce |
[2014-04-07 02:20:21] |
Refer to the documentation for this here: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#Angle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
