Date/Time: Sun, 19 May 2024 08:48:16 +0000
Exporting chart data
View Count: 988
[2014-04-03 19:53:24] |
User39309 - Posts: 15 |
Hi, I am new to Sierra (on the trial). I am exporting data from a chart and am wondering if it is possible to have the tool info (retracement) as part of the output? Or, is it just study values and data series info? Thanks, Jeff |
[2014-04-03 21:03:40] |
Chart drawing data is something that cannot be exported.
[2014-04-30 19:32:24] |
gabby alindogan - Posts: 49 |
HI I am trying to export ohlc info to text file and am able to do so BUT the time stamps seems off. For example SPY latest time stamp is 2014/4/30,18:21:00, 187.90, 188.00, 187.90, 188.00, 136019, 0, 0, 0 even though I just did this 3:30 pm est. Thanks. |
[2014-04-30 19:42:18] |
These times will be in the UTC time zone. There are alternatives for exporting data which will use the time zone within Sierra Chart: http://www.sierrachart.com/index.php?l=doc/doc_ImportExport.html#ExportAlternatives Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
