Date/Time: Fri, 26 Apr 2024 09:19:14 +0000
Stochastics Slow - have 0% - 50% - 100% lines in subgraph of study
View Count: 1077
[2014-04-03 16:12:16] |
User33681 - Posts: 37 |
Attached is a sshot of stochastics in Chart 1 (Independent). Can line values be added for 0%, 50%, and 100% to the study? Can ability to have space between 75-100% fill/no fill color; 0 - 25% fill/no fill color |
have the 0 -100 % showing and between colored.png / V - Attached On 2014-04-03 16:11:50 UTC - Size: 17.71 KB - 346 views |
[2014-04-03 17:11:30] |
Refer to these two sections here: https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingHorizontalLine https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#FillingArea Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-03 17:18:33] |
Sawtooth - Posts: 3976 |
Use 3 instances of the Line study-set all to the same Chart Region as the Stochastics -set the Value to 100, 50, 0 Can ability to have space between 75-100% fill/no fill color; 0 - 25% fill/no fill color
Use 2 instances of the Study Subgraphs Reference study-set the Scale to Automatic on both -set both to the same Chart Region as the Stochastics -check 'Draw Study Underneath Main Price Graph' on both -reference the 100 Line study and the Stochastics study Line1, then use any Fill Top/Fill Bottom draw style pair -reference the Stochastics study Line2 and the 0 Line study, then use any Fill Top/Fill Bottom draw style pair Date Time Of Last Edit: 2014-04-03 17:21:36
