Date/Time: Sun, 28 Apr 2024 09:18:41 +0000
TPO SPLIt
View Count: 1388
[2014-04-03 15:32:34] |
User34464 - Posts: 10 |
Hi, I have looked thru the support board but have not found exactly what I need. Is there a way to have the software automatically split the current profile for the day where the letters are in their own column. I know you can manually split the profiles but I would like it to do it automatically and then when the day passes into the next day the previous split profile resorts back to the letters being un-split and back into its regular profile. I look at 22 different futures and its time consuming to manually adjust these profiles. Thanks for the help... |
[2014-04-03 16:45:39] |
There is no automatic splitting.
