Date/Time: Fri, 03 May 2024 09:28:53 +0000
Sierra on multiple computers
View Count: 1097
[2014-04-03 12:23:07] |
darkpool - Posts: 39 |
Hi, I know it is possible to have Sierra installed on multiple computers, but is it be possible to have it running and connected on both PC's? It doesn't seem to be possible since when I connect on my 2nd pc while already connected on the first, I get logged out with a message saying: Your username and application have logged in another instance (either on the same machine or a different machine) and this api instance has been disconnected I just want to double check that this is indeed correct behavior because I seem to recall reading somewhere on here that I should be able to have Sierra running concurrently on 2 PC's. Maybe im mistaken? Many thanks. |
[2014-04-03 15:44:25] |
Sierra Chart - Max - Posts: 5599 |
Sierra Chart runs on multiple computers at the same time. In your cases it looks like the data feed you are using only allows you to connect from one instance at a time.
Sierra Chart Support |
[2014-04-03 15:46:00] |
Oh ok, so it's a CTS limitation. Darn, that's really annoying!
