Date/Time: Wed, 23 Sep 2026 13:47:22 +0000
help reconnecting to SIM
View Count: 704
| [2021-12-06 15:07:43] |
| User148596 - Posts: 217 |
Hi, it's been a while since I connnected to SIM trading through SC. Can you please tell me how to go about doing that again? Thanks |
| [2021-12-06 17:20:38] |
| John - SC Support - Posts: 47980 |
Just select the option for Trade >> Trade Simulation Mode On. Make sure the checkmark is then placed next to this item and then you are in Simulation Mode. Refer to the following: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes If you are referring to the Simulated Futures Trading Service, then refer to the Setup Instructions for this here: Simulated Futures Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
