Date/Time: Sat, 19 Sep 2026 12:40:08 +0000
Windows error code 10060 still present with disabled firewall
View Count: 1242
[2021-12-06 08:44:49]
User798442 - Posts: 7
Could you please let me know if I can fix it somehow?
Thank you.
Software version: 2333 64-bit | 2021-12-06 07:37:07.382
Primary Thread ID: 1112 | 2021-12-06 07:37:07.382
Usage end date: 2022-02-21 | 2021-12-06 07:37:07.382
Enabled for: Advanced Features 2. | 2021-12-06 07:37:07.382
Enabled for: Sierra Chart Historical Data Service. | 2021-12-06 07:37:07.382
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2021-12-06 07:37:07.382
Enabled for: Delayed Denali Exchange Data Feed. | 2021-12-06 07:37:07.382
Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX) | 2021-12-06 07:37:07.382
Enabled for exchange: Euronext Equities Delayed | 2021-12-06 07:37:07.382
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-12-06 07:37:07.382
Current selected Data/Trading service: Interactive Brokers | 2021-12-06 07:37:07.382
Custom symbol settings values: enabled | 2021-12-06 07:37:07.382
Chart Update Interval: 500 | 2021-12-06 07:37:07.382
Intraday Data Storage Time Unit: 1 | 2021-12-06 07:37:07.382
Time Zone: +00:00:00 (UTC+00) | 2021-12-06 07:37:07.382
2021-12-06 07:37:07 Local computer time in UTC | 2021-12-06 07:37:07.382
2021-12-06 07:37:07 Local computer time in SC Time Zone | 2021-12-06 07:37:07.382
2021-12-06 07:19:28 Server time in UTC | 2021-12-06 07:37:07.382
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-12-06 07:37:07.382
Program path: C:\SierraChart\ | 2021-12-06 07:37:07.382
Data Files path: C:\SierraChart\Data\ | 2021-12-06 07:37:07.382
OS Version Number: 10.0 | 2021-12-06 07:37:07.382
Locale Setting: C | 2021-12-06 07:37:07.382
DLLs: UserContributedStudies_64.dll | 2021-12-06 07:37:07.383
Allowed protected custom studies: zyp_app, zyp_download_free | 2021-12-06 07:37:07.383
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-06 08:34:20.125
DTC Client socket (1) | Creating socket. | 2021-12-06 08:34:20.125
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:34:20.125
DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-12-06 08:34:20.125
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:34:41.188 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:34:41.188
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:34:41.188
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:34:41.188
DTC Client socket (1) | Closed. | 2021-12-06 08:34:41.188
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:34:41.188
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-06 08:34:43.186
DTC Client socket (1) | Creating socket. | 2021-12-06 08:34:43.187
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:34:43.187
DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-12-06 08:34:43.187
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:35:04.215 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:35:04.216
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:35:04.216
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:35:04.216
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:35:04.216
DTC Client socket (1) | Closed. | 2021-12-06 08:35:04.216
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-06 08:35:06.416
DTC Client socket (1) | Creating socket. | 2021-12-06 08:35:06.417
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:35:06.417
DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-12-06 08:35:06.417
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:35:27.464 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:35:27.465
DTC Client socket (1) | Closed. | 2021-12-06 08:35:27.465
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:35:27.465
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:35:27.465
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:35:27.465
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-06 08:35:29.452
DTC Client socket (1) | Creating socket. | 2021-12-06 08:35:29.453
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:35:29.453
DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-12-06 08:35:29.453
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:35:50.490 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:35:50.490
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:35:50.490
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:35:50.490
DTC Client socket (1) | Closed. | 2021-12-06 08:35:50.490
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:35:50.490
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-06 08:35:52.483
DTC Client socket (1) | Creating socket. | 2021-12-06 08:35:52.483
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:35:52.483
DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-12-06 08:35:52.483
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:36:13.522 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:36:13.522
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:36:13.522
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:36:13.522
DTC Client socket (1) | Closed. | 2021-12-06 08:36:13.522
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:36:13.522
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-06 08:36:15.514
DTC Client socket (1) | Creating socket. | 2021-12-06 08:36:15.514
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:36:15.515
DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-12-06 08:36:15.515
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:36:36.563 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:36:36.563
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:36:36.563
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:36:36.563
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:36:36.563
DTC Client socket (1) | Closed. | 2021-12-06 08:36:36.563
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-06 08:36:38.560
DTC Client socket (1) | Creating socket. | 2021-12-06 08:36:38.561
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:36:38.561
DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-12-06 08:36:38.561
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:36:59.584 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:36:59.584
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:36:59.584
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:36:59.584
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:36:59.584
DTC Client socket (1) | Closed. | 2021-12-06 08:36:59.584
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-06 08:37:01.577
DTC Client socket (1) | Creating socket. | 2021-12-06 08:37:01.578
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:37:01.578
DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-12-06 08:37:01.578
DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-12-06 08:37:01.711 *
DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-12-06 08:37:01.711
DTC Client socket (2) | CloseSocket call. | 2021-12-06 08:37:01.711
DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-12-06 08:37:01.711
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-12-06 08:37:01.711
DTC Client socket (2) | Closed. | 2021-12-06 08:37:01.711
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:37:01.712
SC DTC Data with Market Depth | Disconnected from the server. | 2021-12-06 08:37:01.712
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:37:01.712
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2021-12-06 08:37:03.703
DTC Client socket (2) | Creating socket. | 2021-12-06 08:37:03.704
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-12-06 08:37:03.704
DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2021-12-06 08:37:03.704
SC DTC Data with Market Depth | Network connection to server complete. | 2021-12-06 08:37:03.817
SC DTC Data with Market Depth | Starting socket receive thread. | 2021-12-06 08:37:03.817
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-12-06 08:37:03.817
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-12-06 08:37:03.934
SC DTC Data with Market Depth | Sending logon request message. | 2021-12-06 08:37:03.934
SC DTC Data with Market Depth | Received logon response. | 2021-12-06 08:37:04.694
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-12-06 08:37:04.694
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-12-06 08:37:04.694
SC DTC Data with Market Depth | Successfully connected. | 2021-12-06 08:37:04.694
SC DTC Data with Market Depth | Trading is not supported. | 2021-12-06 08:37:04.694
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NYSE_NASDAQ_NYSEMKT | 2021-12-06 08:37:04.694
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NASDAQ | 2021-12-06 08:37:04.694
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2021-12-06 08:37:04.694
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE_NASDAQ_NYSEMKT | 2021-12-06 08:37:04.694
SC DTC Data with Market Depth | Received security definition for symbol ADR-NYSE_NASDAQ_NYSEMKT | 2021-12-06 08:37:04.910
SC DTC Data with Market Depth | Received security definition for symbol TICK-NASDAQ | 2021-12-06 08:37:04.910
SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2021-12-06 08:37:04.910
SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE_NASDAQ_NYSEMKT | 2021-12-06 08:37:04.910
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:37:22.605 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:37:22.605
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:37:22.605
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:37:22.605
DTC Client socket (1) | Closed. | 2021-12-06 08:37:22.605
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:37:22.605
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-06 08:37:24.594
DTC Client socket (1) | Creating socket. | 2021-12-06 08:37:24.594
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:37:24.594
DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-12-06 08:37:24.594
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:37:45.625 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:37:45.625
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:37:45.625
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:37:45.625
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:37:45.625
DTC Client socket (1) | Closed. | 2021-12-06 08:37:45.625
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-06 08:37:47.623
DTC Client socket (1) | Creating socket. | 2021-12-06 08:37:47.624
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:37:47.624
DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-12-06 08:37:47.624
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:38:08.660 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:38:08.660
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:38:08.660
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:38:08.660
DTC Client socket (1) | Closed. | 2021-12-06 08:38:08.660
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:38:08.660
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-06 08:38:10.656
DTC Client socket (1) | Creating socket. | 2021-12-06 08:38:10.656
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:38:10.656
DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-12-06 08:38:10.656
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:38:31.706 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:38:31.706
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:38:31.706
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:38:31.706
DTC Client socket (1) | Closed. | 2021-12-06 08:38:31.706
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:38:31.706
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-06 08:38:33.701
DTC Client socket (1) | Creating socket. | 2021-12-06 08:38:33.701
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:38:33.701
DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-12-06 08:38:33.701
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:38:54.743 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:38:54.743
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:38:54.744
DTC Client socket (1) | Closed. | 2021-12-06 08:38:54.744
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:38:54.744
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:38:54.744
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-06 08:38:56.731
DTC Client socket (1) | Creating socket. | 2021-12-06 08:38:56.731
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:38:56.731
DTC Client socket (1) | Connecting to IP: 8.18.161.135. | 2021-12-06 08:38:56.731
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:39:17.783 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:39:17.784
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:39:17.784
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:39:17.784
DTC Client socket (1) | Closed. | 2021-12-06 08:39:17.784
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:39:17.784
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-06 08:39:19.778
DTC Client socket (1) | Creating socket. | 2021-12-06 08:39:19.779
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:39:19.779
DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-12-06 08:39:19.779
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:39:40.816 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:39:40.816
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:39:40.816
DTC Client socket (1) | Closed. | 2021-12-06 08:39:40.816
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:39:40.816
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:39:40.816
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-06 08:39:42.811
DTC Client socket (3) | Creating socket. | 2021-12-06 08:39:42.811
DTC Client socket (3) | New receive buffer size: 5242880 | 2021-12-06 08:39:42.811
DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2021-12-06 08:39:42.811
DTC Client socket (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:40:03.840 *
DTC Client socket (3) | CloseSocket call. | 2021-12-06 08:40:03.841
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:40:03.841
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:40:03.841
DTC Client socket (3) | Closed. | 2021-12-06 08:40:03.841
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:40:03.841
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-06 08:40:05.841
DTC Client socket (1) | Creating socket. | 2021-12-06 08:40:05.842
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:40:05.842
DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-12-06 08:40:05.842
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:40:26.879 *
DTC Client socket (1) | CloseSocket call. | 2021-12-06 08:40:26.879
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:40:26.879
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:40:26.879
DTC Client socket (1) | Closed. | 2021-12-06 08:40:26.879
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:40:26.879
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2021-12-06 08:40:28.872
DTC Client socket (3) | Creating socket. | 2021-12-06 08:40:28.872
DTC Client socket (3) | New receive buffer size: 5242880 | 2021-12-06 08:40:28.872
DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2021-12-06 08:40:28.872
DTC Client socket (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-12-06 08:40:49.903 *
DTC Client socket (3) | CloseSocket call. | 2021-12-06 08:40:49.903
DTC Client socket (3) | Closed. | 2021-12-06 08:40:49.904
DTC Client socket (0) | CloseSocket call. | 2021-12-06 08:40:49.904
SC Data - All Services | Disconnected from the server. | 2021-12-06 08:40:49.904
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2021-12-06 08:40:49.904
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10047 | 2021-12-06 08:40:51.902
DTC Client socket (1) | Creating socket. | 2021-12-06 08:40:51.903
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-06 08:40:51.903
DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2021-12-06 08:40:51.903
Date Time Of Last Edit: 2021-12-06 09:23:42
[2021-12-06 09:24:58]
You definitely have a connectivity issue, either somewhere on your computer or network:
You have to keep looking to identify where the issue is. The issue is somewhere. Can be on your computer, can be with your internal network, can be with your ISP.
it might help to do a tracert to ds1.sierracharts.com from the Windows commandline
Refer to:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
Date Time Of Last Edit: 2021-12-06 12:05:07
[2021-12-06 09:51:19]
I've changed back to version 2332 and issue is gone.
Something is not OK with 2333 version.
Thank you.
[2021-12-06 11:47:36]
No, this is definitively not the issue with the particular Sierra Chart version. That is impossible. It is going to be caused by a firewall on your computer If a different version is not connecting.
It is your firewall detecting a different version of Sierra Chart and blocking it. This actually is confirmation that it is a firewall causing the problem. And disabling it is not sufficient enough.
Date Time Of Last Edit: 2021-12-06 11:48:21
