Date/Time: Sun, 01 Nov 2026 11:05:35 +0000
Is it possible to link the data from that feed to Sierra chart : https://polygon.io/sip ?
View Count: 885
| [2021-12-03 18:58:37] |
| GravisHTG - Posts: 321 |
I wonder , I might get my options data from them.
| [2021-12-03 19:19:39] |
| John - SC Support - Posts: 48377 |
If a data provider can send the information using the DTC protocol, then Sierra Chart can accept it. Refer to the following: DTC Protocol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
