Date/Time: Sun, 01 Nov 2026 11:05:35 +0000
15 days tryal
View Count: 763
[2021-12-02 15:26:20]
User317099 - Posts: 2
hi, i am about to finish the 15 day trial. i need a consultation.
next week, I would like to buy a month of your platform and data, I specify what I need, so you will be the one to recommend the package, I need data as precise as possible, I will try to use an algorithm to scale small 2- 3 ticks on ES.
i think i use a vps server to minimize latency, can you advise me how to do to minimize order execution latency?
[2021-12-02 17:20:36]
For data, we recommend using our Denali Exchange Data Feed. Refer to the information here:
As for order execution, we recommend using our Teton Order Routing Service (if you can). Refer to the information here:
Also, refer to the following:
Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading
