Date/Time: Sun, 01 Nov 2026 11:05:56 +0000
multiple trading accounts
View Count: 989
| [2021-12-02 15:19:36] |
| User401511 - Posts: 33 |
Is there a way to trade/link two accounts from one Sierra Chart and to be more specific, one DOM using one data feed. Currently using 'Trading Evaluator [Trading]' service for Apteros tryout, but want to trade my CGQ account at the same time thanks |
| [2021-12-02 17:14:43] |
| John - SC Support - Posts: 48377 |
If you are wanting to trade these separately, then the best way to do this is to install a second Sierra Chart on the same computer. You can then use one instance to connect to Apteros and the other to connect to CQG. You will be able to get the Denali data into both instances without a problem and there is no additional costs for this setup. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart There is not support to be able to duplicate trades between disparate services, if that is what you are asking for. To understand what we do have available in this respect, refer to the following: Order Allocation to Trade Accounts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
