Date/Time: Sat, 14 Nov 2026 08:04:07 +0000
Numbers bars calculated values addition
View Count: 1593
[2021-12-02 10:07:03]
User719310 - Posts: 23
is it possible to add whether a poc is naked or not/has been intersected or not, to the numbers bars calculated values -
or any other study for that matter?
[2021-12-02 15:46:06]
If you are wanting the POC per bar (although it does not differentiate if it is a Naked POC or not), then you can use the Numbers Bars to highlight the POC in the bar and also the option to Extend the POC until future intersection. Refer to the following Input:
Numbers Bars: Highlight Point Of Control In
Otherwise, this is something we would have to add. Are you wanting to be able to see the extension of the POC line stop when it intersects with the first bar it intersects, whether it is part of the same period or not?
[2021-12-07 09:47:03]
I do this already in my charts.
What I am interested in is the info of these naked levels (mainly whether they are still naked or not) being able to be put into the write bar and study data to file.
If sierra charts has this info already as the drawing of the extension lines stops after intersection, can it be put into a study and the write bar and study data to file
Date Time Of Last Edit: 2022-05-03 22:00:38
[2021-12-07 17:19:35]
This is something we would need to add, or you would have to program.
[2021-12-08 06:32:46]
OK could you please do this? Or point me in the right direction, is there a variable that holds this info?
[2021-12-08 08:20:51]
binaryduke - Posts: 387
Commercial solution that does exactly what you are describing:
https://www.emojitrading.com/product/poc-pro/
You can access the nearest three naked POCs (in fact nearest three POCs in various states based on naked, or how the levels have traded based on order flow) via subgraphs.
[2022-05-03 22:04:28]
How should I go about doing this, Is there a variable in ACSIL that stores whether or not a poc is naked?
Date Time Of Last Edit: 2022-05-04 13:13:36
