Date/Time: Sun, 01 Nov 2026 11:05:53 +0000
Delta Footprint Chart
View Count: 1005
[2021-12-01 22:52:02]
SouthUKTrader - Posts: 3
Hiya,
I know you can have the numbers bar show delta, but it puts it all in a single column.
How would I get it so the buy and sell is on different sides. It doesnt need to look diagonally. See the screenshot.
Thanks very much for your help with this.
imageDelta Footprint chart.JPG / V - Attached On 2021-12-01 22:51:24 UTC - Size: 26.79 KB - 322 views
[2021-12-01 23:16:39]
There is not an option to display the Delta on the Bid or Ask side for a direct comparison. It only does that when doing a Diagonal Comparison.
[2021-12-02 06:44:43]
Thanks for your response John.
How would I get it work diagonally please ?
Thanks again.
[2021-12-02 15:19:36]
Just set the Input for Column n Numbers Bars Text to Ask Vol Bid Vol Difference Diagonal. Refer to the information here:
Numbers Bars: Numbers Bars Text Types
Date Time Of Last Edit: 2021-12-02 15:19:50
