Date/Time: Wed, 08 May 2024 05:37:57 +0000
System Notification Message
View Count: 479
[2021-11-29 15:58:11] |
Tony - Posts: 460 |
Hi, I receive System Notification Message occasionally on Sierra Chart startup, there is a check box at the bottom of the message window, says 'Do not show this again', I check the box, the same message still appears the very next day, wonder if it can be fixed? Thanks, |
[2021-11-29 18:17:41] |
John - SC Support - Posts: 31441 |
This is being looked into.
[2021-12-07 15:54:50] |
If you continue to have this problem, press the button to View in Web Browser, copy it and paste the entire contents here.
