Date/Time: Tue, 07 May 2024 08:30:45 +0000
Symbol Settings not working
View Count: 819
[2014-04-02 16:04:49] |
superdoug3 - Posts: 40 |
I have set NQ$# intraday settings to be RTH when I am on the west coast of Canada (LA time zone) - see first attachment I have included Daily OHLC in my study and you can see it us using midnight for my intraday start time - see 2nd attachment. |
2014-04-02_sym-settings.png / V - Attached On 2014-04-02 16:03:29 UTC - Size: 55.76 KB - 324 views 2014-04-02_Sym-settings2.png / V - Attached On 2014-04-02 16:03:57 UTC - Size: 103.87 KB - 324 views |
[2014-04-02 16:42:16] |
This is not the correct way to do this. Refer to the Daily OHLC documentation here: https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s137 You need to set the Session Times in Chart >> Chart Settings. Also in the Symbol Settings image you posted, you have set the Start Time to 6 minutes and 30 seconds past midnight. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
