Date/Time: Fri, 03 May 2024 13:48:15 +0000
Daily data missing / symbol highlighted red on chart
View Count: 451
[2021-11-29 14:57:24] |
aelagha - Posts: 31 |
Hi there, Daily data is missing from chat. This happens on two symbols, mini Corn and Rough Rice on CBOT. My realtime data feed subscription is up to date (CQG).The symbol is highlighted red in the chart. I tried deleting and uploading the data again but no luck. I do receive intraday data and the 240min chart is updating. See attached capture. Any thought what might be going on?? Thanks, |
Capture.PNG / V - Attached On 2021-11-29 14:57:04 UTC - Size: 120 KB - 132 views |
[2021-11-29 15:14:58] |
We are checking on the historical daily data issue with this particular CQG symbol. The red highlighting of the symbol indicates there is an alert true for the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-29 15:15:04
[2021-11-29 15:23:54] |
We have set a multiplier of 1000 for historical Daily data for ZR futures for CQG. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-29 15:24:18
[2021-11-29 17:56:30] |
nice. it works. thanks.
[2021-11-30 01:53:30] |
two follow up questions: 1) prices on chart are in thousands, i.e. 14500.00 instead of 14.500. Do I have to do anything else to fix this? 2) the symbol in the chart header is still highlighted in red. Is there any significance to this? thx |
[2021-11-30 09:13:40] |
1. This is how CQG presents these values. We would recommend just leaving them alone. 2. Clear the alert: Study/Chart Alerts And Scanning: To Enter an Alert Condition on the Main Chart/Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
