Date/Time: Thu, 02 May 2024 00:48:08 +0000
Missing decimal in Spreadsheet cells J94 and J96
View Count: 673
[2021-11-29 02:59:25] |
j4ytr4der_ - Posts: 918 |
I just set up some new Rithmic evaluations, first time ever using the new Rithmic Direct option. Immediately I ran into a problem with a spreadsheet. Cells J94 and J96 which report the last working entry and exit order prices, are missing their decimal point. If I switch back to any other data feed, everything is fine. It's only these two cells, all other reports of price appear to be OK (J14 and J12 for example). Is this something that can be fixed? Is there some setting somewhere that could be causing this? Obviously I can't trade with these evaluation accounts until I sort this. Thanks. |
[2021-11-29 04:56:15] |
This will be resolved in the next release. The Real-time Price Multiplier needs to be applied to those cells.
