Date/Time: Sun, 28 Apr 2024 02:36:32 +0000
ACS Buttons
View Count: 2178
[2013-03-22 12:42:55] |
N2S - Posts: 15 |
Can you please make the ACS Toolbar buttons clickable when the Hand tool is activated ? In all of my charts I use the constant range scale mode and the hand is activated but unfortunately I can't use the buttons to activate the (brilliant!) trade management study. |
[2013-03-22 16:51:09] |
We should be able to do this as long as there are no studies on the chart that have requested mouse pointer events when an ACS ToolBar button is selected.
[2013-03-25 08:20:19] |
N2S - Posts: 15 |
Ok. Thank you.
[2013-03-25 23:48:35] |
This will be resolved in the next release.
