Date/Time: Tue, 07 May 2024 07:26:04 +0000
Volume/Open Int. Multiplier Effects on Volume By Price Study
View Count: 506
[2021-11-26 16:39:10] |
frozentundra - Posts: 84 |
Greetings, I am observing unexpected behavior when loading a simple candlestick chart for any US equity (QQQ used in this example, but it is reproducible on any US equity I have tried). I have my global symbol settings for equities setting the Volume/Open Int. Multiplier to `0.001`. When I load a daily chart with a Volume By Price study for timespan of Visible Bars, the Volume By Price study looks to be rendering incorrectly. If I navigate to Chart Settings -> Advanced Settings 2 -> Volume/Open Int. Multiplier and change it back to `1` and hit Apply, the VbP study renders correctly. Switching it back to my desired setting of `0.001` will render it incorrectly again. Here is a short gif demonstrating how to reproduce this behavior. Is this expected behavior? Thank you in advance. |
vp study in SC.gif / V - Attached On 2021-11-26 16:38:11 UTC - Size: 3.99 MB - 137 views |
[2021-11-29 15:58:21] |
John - SC Support - Posts: 31419 |
We are not able to reproduce this on any equity, even with QQQ. Please get us a copy of that chart in its own chartbook so we can take a look at what might be causing what you are seeing. Follow these instructions to get us the chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-29 18:27:24] |
Done, attached.
sc support vbp issue.Cht - Attached On 2021-11-29 18:27:00 UTC - Size: 4.15 KB - 124 views |
[2021-11-29 19:29:22] |
Here is what we see when we open your chart: http://www.sierrachart.com/image.php?Image=1638213948950.png And changing the Open Int./Volume Multiplier does not change anything. Here is the image with it changed to a value of 1: http://www.sierrachart.com/image.php?Image=1638214020852.png So we are not sure why you are seeing what you are. Please try starting a new chart and enter a new Volume by Price study on it and let us know what happens. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-29 20:05:17] |
Interesting, so that would imply that it is something in my Global Settings that might be causing this? - File > New Historical Chart > QQQ daily - Studies > Add > Volume By Price - Modified VbP to Right Align and Align to far right and it shows me the same issue, but with bars instead of candles since I didn't touch the other chart settings. |
sc daily vbp issue new chart.jpg / V - Attached On 2021-11-29 20:03:56 UTC - Size: 223.29 KB - 99 views sc daily vbp issue new chart 2.jpg / V - Attached On 2021-11-29 20:05:05 UTC - Size: 194.27 KB - 102 views sc daily vbp issue new chart 3.jpg / V - Attached On 2021-11-29 20:05:09 UTC - Size: 172.68 KB - 102 views |
