Date/Time: Sat, 02 Jul 2022 07:38:02 +0000
Zig zag cumulative volume
View Count: 371
[2021-11-25 03:54:11] |
User575399 - Posts: 273 |
I noticed The zig zag cumulative volume study will repaint the prior bars if the trend changes . Giving false indications . Any way to prevent / change this ? |
[2021-11-25 22:17:36] |
Up
[2021-11-26 08:06:40] |
User907968 - Posts: 705 |
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=133&Name=Zig_Zag#ZigZagReversesAtWrongBar Did you try using calculate on close? Date Time Of Last Edit: 2021-11-26 08:07:28
[2021-11-26 17:18:53] |
Also how do you have these Inputs set: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=133&Name=Zig_Zag#Inputs_InputDataForHigh https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=133&Name=Zig_Zag#Inputs_InputDataforLow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-26 17:30:10] |
I have all the inputs set correctly. I saw some previous posts with the same concern and no solution Is this just the way it is? |
[2021-11-28 20:05:16] |
So their is no fix for this? I checked all the settings and it still will go back and change which makes this useless |
[2021-11-28 20:43:30] |
Set this input to Yes and this is all that you can do: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=133&Name=Zig_Zag#Inputs_CalculateNewValuesOnBarClose Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-28 21:53:25] |
Tried that.
[2021-11-29 00:07:37] |
here is what I mean. See how it is off and it will also repaint the previous bars
Date Time Of Last Edit: 2021-11-29 00:19:48
[2021-11-29 08:31:07] |
The study configuration is not consistent bewteen the two images, so how can you possibly compare them? 249 is set to 'Total Volume, High, Low, 1, 0.5 0.75, 4, Yes, Yes' 252 is set to 'Total Volume, Last, Last, 2, 0.5 0.75, 4, Yes, Yes' Also, it is normal to repaint if a reversal starts but is not confirmed, but that is dependant on your configuration. Using image 249 configuration - a reversal has started, but until price moves 0.5% off of the most recent swing high the reversal is not confirmed. As price does not move the specified distance, the move is not confirmed and the reversal is invalid, ergo the up trend continues and the volume bars are correctly repainted accordingly. Date Time Of Last Edit: 2021-11-29 08:31:30
[2021-11-29 22:08:56] |
Those were just the screenshots. trust me it happens with any setting
