Date/Time: Sun, 05 May 2024 19:32:04 +0000
Gene Sheldon
View Count: 987
[2014-04-02 09:14:43] |
User72965 - Posts: 114 |
http://www.sierrachart.com/image.php?l=1396429660523.png Notice no volume #'s on the Red&Green Bars By the 1880.25 price indicator???(Right Side<>Mid Price Scale) Should be #'s and % there?? Not there ?? I don't think working right ? Changed nothing in Chart settings Advanced 2 DOM Graph ?? Don't know how to fix it ??? Thx : Gene :) |
[2014-04-03 07:34:04] |
We have run a test and we do not see a problem with this: http://www.sierrachart.com/image.php?l=1396510427757.png Can you post an image of the Chart Settings >> Advanced Settings 2 window for the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
