Date/Time: Sun, 01 Nov 2026 11:51:08 +0000
highlight values on right side of chart
View Count: 1517
| [2021-11-19 19:33:27] |
| User525965 - Posts: 180 |
Hi, I'm trying to figure out how to get all my market profile charts to highlight the value area price on the right pane. See attached crude chart for what I want, and the other attachment does not. I'm not sure what setting does this. Thanks! |
| [2021-11-19 21:44:31] |
| John - SC Support - Posts: 48377 |
If you want to see ALL of the Value Area Lines values in the Price Scale, then set the Extend Value Area Input on the TPO Study to End of Window, then in the Subgraphs, turn on the Value Label for the Subgraph named Value Area Extension Lines. Refer to the following for the Input: For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-19 21:44:32] |
If you want to see ALL of the Value Area Lines values in the Price Scale, then set the Extend Value Area Input on the TPO Study to End of Window, then in the Subgraphs, turn on the Value Label for the Subgraph named Value Area Extension Lines. Refer to the following for the Input: Time Price Opportunity (TPO) Profile Charts: Extend Value Area And refer to the following for the Value Label: Chart Studies: Subgraphs Tab >> Name and Value Labels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-19 21:45:24
