Date/Time: Sun, 01 Nov 2026 11:50:58 +0000
Sign up for Sierra Chart Standard Package + Denali + Teton
View Count: 1009
| [2021-11-19 17:50:14] |
| User579979 - Posts: 12 |
Dear Madam/Sir, I would like to start using Sierra Chart Service Package 10 (Standard package + Denali Feed) + Sierra Chart Teton Order Routing. I recently opened a AMP Futures Account and hope that your Teton Order routing soon becomes available for AMP clients! In the mean time I will have to use a reliable order routing service. Which one do you recommend that is comparable to Teton? Do I have to sign up for Sierra Chart service package 10 through AMP Futures or you? Will trade the Micro Nasdaq Futures only; so no bundle. Top of Book. Exchange: only CME! Do the Exchange Fees go thru Sierra Chart? Please let me know. Thank you, |
| [2021-11-19 18:06:35] |
| John - SC Support - Posts: 48377 |
With AMP you can use either CQG or Rithmic for your order routing. Both of them are about the same, but you definitely will want to use the Denali Exchange Data Feed for your data. You can not get Sierra Chart through a broker, therefore you need to go through us to get everything for Sierra Chart, including the Denali Exchange Data Feed and the exchange fees. To add funds to your account and activate a Service Package, refer to these instructions: Sierra Chart Purchase and License Information: Instructions To setup the Denali Exchange Data Feed for the CME Group data, refer to the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-19 18:42:16] |
Thank you very much for your response!
