Date/Time: Sun, 01 Nov 2026 11:50:44 +0000
[Programming Help] - how to display total delta of micro Nq and NQ together on the same chart
View Count: 934
| [2021-11-19 10:30:28] |
| User61576 - Posts: 458 |
i am using a chart of EMQ contract and with a study Cumulative Delta bars to display on the chart the total detla i would like to display the adjusted micro delta on the same chart and combine the delta together (both NQ and micro NQ) adjusted = micro delta /10 = 1 NQ delta and to do that without using the spreadsheets which I hate and can not use is there any way to create a line that is based on other charts inputs and multiply them to be adjusted? |
| [2021-11-19 11:24:50] |
This is outside the scope of our support. Maybe another user can help.
| [2021-11-19 11:43:10] |
can i create a positive spread contract with a ratio of 1:10 (NQ + Micro NQ)?
| [2021-11-19 15:59:18] |
| John - SC Support - Posts: 48377 |
Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-19 16:07:12] |
| Sawtooth - Posts: 4359 |
You can create custom OHLC bars using the Spreadsheet Formula (Bar) study. Note: Despite its name, this is not a spreadsheet study. It uses Simple Alert formula syntax. |
