Date/Time: Fri, 06 Nov 2026 09:06:12 +0000
How to enable cursor on a chart
View Count: 2570
| [2021-11-18 19:09:09] |
| User643426 - Posts: 144 |
Can you please tell me how to enable the cursor when I'm scrolling over a chart so I can see the exact price and high and low of a range bar? I see the "Global Cursor On" and "Symbol Cursor On" features in the Tools menu, but this doesn't turn on the cursor for the chart. I also do not see an "enable cursor" function in the Chart settings. Thank you. |
| [2021-11-18 21:33:39] |
| John - SC Support - Posts: 48449 |
Refer to the following: Chart Drawing Tools: Chart Values/Crosshair For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
