Date/Time: Sat, 04 May 2024 19:08:21 +0000
User gene sheldon
View Count: 1082
[2014-04-01 19:02:12] |
User72965 - Posts: 114 |
On the pullback column?? It's there with bars.. But no volume On the bid & ask. Can't lengthen the bars either. Downed 1115 this a.m. Was working on 1107 version ?? Me ?? or something in the software. All ok in Chart Settings. I changed nothing ?? |
[2014-04-01 19:57:04] |
We see no problem with Numbers Bars and IQ Feed on version 1115. Please post an image of the chart so we can have a better understanding of what the problem is. Here are the instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-01 22:47:58] |
It's the DOM Graph in Chart Settings Advanced #2, I don't get the # of trades or The %'s only the red & Green bars. (Bid&Ask) No volume ?? Thx Gene |
[2014-04-01 23:09:35] |
It works correctly when we test it: http://www.sierrachart.com/image.php?l=1396393694218.png Check to be sure that Global Settings >> Chart Settings >> Maximum Depth Levels Displayed is set to 100. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
